2000 sh motor swap into eg?
I have a friend who is interested in putting a h22a4 from a prelude sh into a eg. i know its possible but would it have any problems with the atts tranny or something similiar to that? could he use the normal axles that one would use for a h22a swap?thanx again....
Re: 2000 sh motor swap into eg? (93h22a4)
Don't do it. I repeat DO NOT. The engine AND the transmission will NOT work! It's a different block, and a different transmission entirely.
It WILL NOT work. Trust me! I know.
Re: 2000 sh motor swap into eg? (jeff652)
He's saying it'll cost wayyy more than it should just to swap ordinary H22 in.
I would trust Jeff's opinion definitely. Trust me. I changed a clutch in an ATTS prelude and it was a project just doing that.
Re: 2000 sh motor swap into eg? (poison)
. . . it is even worse than that.
The ATTS equipped H22 has a COMPLETELY different casted block. They had to cast the block differently to relocate the oil filter in order to make room for the ATTS unit itself.
There is no half-shaft on the planet that will bolt to an ATTS specific H22 block . . .
how effective is atts tho?
not much at all. I would prefer the factory lsd rather than a computerized LSD
Re: 2000 sh motor swap into eg? (J2turbo21)
damn, you guys just saved me alot of money. i hadnt goten any replys in a while so i was going to go buy it today. but my instincs told me to check one last time and look what happened.. Thanx alot......
