95 GSR cluster in a 92 civic hatch
Re: 95 GSR cluster in a 92 civic hatch (wacllp)
Integra Blue Left Side Plug (13 pins)
1. BLU - Tach signal
2. GRN/ORG - Check engine indicator
3. YEL/RED - Oil pressure switch
4. -
5. WHT/BLU - Charge indicator
6. -
7. YEL/GRN - Coolant temp
8. BLK - Ground
9. RED/BLU - Cruise control (if you have cruise)
10. YEL - Hot
11. -
12. PINK - Maintenance (not used)
13. -
Integra Right Side Blue Plug (16 pins)
1. GRN/RED - E-Brake signal
2. RED/GRN - High beam
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
9. BLU/RED - ABS (not used)
10. GRN - Trunk switch
11. ORG - Vehicle speed sensor
12. -
13. BLU/WHT - Low fuel (not used)
14. YEL/WHT - Fuel gauge
15. LGT. GRN/RED - Door switch (not used)
16. RED/BLU - Seat belt
Civic Left Side Grey Plug (12 pins)
1. YEL/WHT - Fuel gauge
2. YEL/BLU - Vehicle speed sensor
5. WHT/BLU - Charge
6. YEL/RED - Oil pressure switch
7. -
8. BLU - Tach signal
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
Civic Right Side Grey Plug (10 pins)
1. RED/GRN - High beam indicator
2. GRN/RED - E-Brake signal
3. -
4. -
5. GRN/ORG - Check engine indicator
6. BLK - Ground
8. YEL - Hot
9. GRN - Trunk switch
10. BLU/WHT - Seat belt
4. -
6. -
8. BLK - Ground
10. YEL - Hot
11. -
13. -
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
12. -
5. WHT/BLU - Charge
7. -
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
3. -
4. -
6. BLK - Ground
8. YEL - Hot
trooper0641
04-20-2004 07:28 AM
skribblah
12
09-15-2003 09:30 AM
