OBD-1 B18C1 into '92 VX hatch, what to do about O2 sensor?
Alright, everything is in and running, but the CEL 41 needs to go off.
I have an old cat from my '96 GS-R, I was thinking I could use it, plug the other O2 hole. Do I use the 4 wire O2 that the GS-R would use, or do I use the 5 wire VX O2 sensor? I'm going to have to extent the wires obviously, because the 02 goes in the front of the exh. manifold on the VX.
Which O2 do I use???
Re: OBD-1 B18C1 into '92 VX hatch, what to do about O2 sensor? (Shiroi Hakucho)
USE the GSR. There should be a plug for the O2 that is on the engine wire harness.
Re: OBD-1 B18C1 into '92 VX hatch, what to do about O2 sensor? (Jun)
Word, thanks. You know about moving the IAC wire for the ECU? That's where I'm stuck now. Thanks for your help
DALE-EK4
40
05-03-2007 11:41 AM
Sleepy_Red_hatch
08-08-2005 12:22 PM
EARLdaSQUIRREL
01-13-2003 07:09 PM
