wiring diagram qeustion
Re: wiring diagram qeustion (crix180)
its pretty straight foward
but here is one from the sexy katman.
Tho, katman might want to update that if you are putting swap into a DA, you need to switch the wiring because of the power steering something or other
I cant remember off hand, but just need to switch B19 because on the USDM ecu, it does something with power steering switch or something, and on the JDM ecu, its in a different pin, i cant remember tho, check a helms.
But u wont have to worry about it
As for the rest of wiring, use stock harness, extend air intake temp sensor wire, extend oil pressure switch wire, and i think thats all you have to extend, I cant think of anything else off the top of my head.
This diagram makes wiring easy as pie tho
props to katman for helpin us all out
[Modified by irev210, 9:29 PM 3/6/2003]
Re: wiring diagram qeustion (irev210)
There is no OBD 0 GSR (dual butterfly) ecu that I am aware of. I think katman may have made a mistake
If there was, it would have saved a lot of headache from converting my CRX to OBD I.
[Modified by Slurp56, 10:27 PM 3/6/2003]
leecivic
08-25-2016 09:25 AM
I Love My 4 door
11-08-2009 03:59 PM
