what mounts for a b18c1 in 96 ek
Old 02-25-2003, 10:55 PM
GRAVEDIGGER's Avatar
Default what mounts for a b18c1 in 96 ek
will the all the stock gsrs mounts bolt right up,if not what mounts to use. also about the wiring harness,what extra wires do i need to run ie,v-tec solenoid,knock sensor . what else? any help is appreciated
Old 02-25-2003, 11:29 PM
civicrtype's Avatar
Default Re: what mounts for a b18c1 in 96 ek (rp2000Rless)
I got help on this topic so in return I will pass on the knowledge:
Driver Side Mount from 99-00 SI (one under cam gears)
Rear Tranny bracket from 99-00 SI
Front Tranny bracket you can use the one that came wit your GSR swap
Front A/C bracket use the one off of ur GSR swap
(If you want to keep A/C use the front A/C bracket from a DOHC del sol)
All the rubber mounts and the top tranny bracket just use ur stock EK ones. Good luck.
Old 02-26-2003, 09:16 AM
Trey's Avatar
Default Re: what mounts for a b18c1 in 96 ek (civicrtype)
everything you need is here:
http://www.jspectuning.com/6gen
Old 02-26-2003, 09:25 AM
95hbMatt's Avatar
I've got a 99-00 Si rear mount & bracket for sale if you need one!
hspoon
02-21-2007 08:43 AM
invisible
01-09-2007 11:05 AM
JDM99DC2
04-12-2005 06:15 PM
teamm_AP1
12-09-2004 01:24 AM
GOLDBERG
11-15-2003 06:37 AM
Quick Reply: what mounts for a b18c1 in 96 ek
