EF Hydro B-Series Axle Question????
Old 03-05-2003, 01:58 PM
dkim48's Avatar
Default EF Hydro B-Series Axle Question????
I searched but could not find it. I need to know which axles are used. I am building up a drag crx and hydro trannys are a lot easier to find parts on. I used a hasport billet kit and modified the tranny mount so it can fit the hydro tranny but I need to know which axles will fit. I have someone that has the driveshaftshop stage II axles for a 94+GSR w/abs and I need to know if those will fit. Please help me out.
Thanks in advance,
Daniel
Old 07-20-2003, 08:08 PM
Jared's Avatar
Default Re: EF Hydro B-Series Axle Question???? (dkim48)
any integra axles will fit, just remove the outer dust rings on the hubs and axles and match the halfshaft with the axles. a 94+ setup will be fine
Old 07-21-2003, 03:52 PM
dkim48's Avatar
Default Re: EF Hydro B-Series Axle Question???? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">any integra axles will fit, just remove the outer dust rings on the hubs and axles and match the halfshaft with the axles. a 94+ setup will be fine</TD></TR></TABLE>
Bringin it back from the dead. Thanks bro, its been a while now but I finally got everything together(94+Setup).
blake22
02-18-2007 06:59 AM
bluedxhatch
Suspension & Brakes
05-21-2006 01:17 PM
VtecKiDD
12-29-2005 09:45 AM
titerex
12-22-2004 03:55 AM
dkim48
03-05-2003 03:03 PM
Quick Reply: EF Hydro B-Series Axle Question????
