Little help with a b16 in a eg, PLease!
Well I just put a b16A2 in a 93 hatch that previously had a d16 in it before. Iused the wireing harness from the d16 since the b16 had a JDM harness. I didn't feel like lengthening the wires, and I wasn't sure what to do about the map sensor.
So the problem is I don't have any spark. nor do I have power to the distributor. I am getting a pulse to the injectors....could there be a compatibility problem with the harness? I am also useing a chiped p28 ECU. Any help would be appreciated. thanks.
Re: Little help with a b16 in a eg, PLease! (nsxmatt)
Grounds are all on(tranny engine etc..) I alos checked all the fuses and the main relay. All of them are ok. Any other ideas. Thanks.
I so want to tourch it! The harness was working on the other engine, justdidn't let vtec engage, so i rewired that part of it. the engine is cranking over, just no spark.....or power to the dist...
yellowcanary.
04-18-2015 11:47 PM
stevomc51284
05-03-2005 04:42 AM
my_slow_civic
10-27-2004 09:43 AM
