What kind of Fuel Mangment??
Guest
Posts: n/a
Ive got a built N/A b16. So what kind of fuel managment should i use?? I was thinking about hondata 2B. Im not really all that wise to this kind of stuff. Ive got AEM FPR, Bennen Fuel rail. Do i need different injectors??? How long will it take to tune one on the Dyno with a guy that knows his stuff?? They charge by the hour. Any help would be great.
Re: What kind of Fuel Mangment?? (stroker)
Hondata will work great... With a good Hondata tuner you should be tuned within that amount of time depending on degree work you have done... What compression and cams are you running??? That kinda varies what injectors you eventually decide on... If your motor is still a ~1.6L and you are running high compression I would just go with some 310's... Always better to go above and lean out what you don't need rather than be lean and try to richen up through adjusting injector D/C and FP... Latez
Re: What kind of Fuel Mangment?? (Kataku2K3)
Hondata is all you need for your fuel management needs. It only costs about $500 tuned and installed. Compare that to a VAFC that costs $300 then dyno time that costs $100-$150 with lower results.
Guest
Posts: n/a
Re: What kind of Fuel Mangment?? (Maximus)
it depends.... do you want to do your own tuning or trust some shop to do it? if you wana do it yourself then i would highly recomend the aem ems. i have used both hondata and aem ems and the ems is 100X better for doing your own tuning. you can tune the car while your driving around, no need to turn the car off. and you dont have to have 3 diff pieces of software, the burner and the emulator. all you gota have is a serial port on a laptop and a wideband (automapping ownz..)
dAng! Kris
11-28-2003 08:36 PM
gsr98vtec
12-19-2001 06:41 AM
