where is the fuel pump fuse?????????
like the topic says... finished my swap and fuel pump won't turn on.
i think i shorted it out.
the master relay is fine and the fuel pump is brand new... oh and the ground is good.
either its the fuse or something in the wiring from the dash back???!!!
any suggestions!
-Bryan-
any suggestions!
-Bryan-
Re: where is the fuel pump fuse????????? (Kamin)
new fuel pump and it dont work? try looking at your ecu fuse under your hood...cuz if your ecu fuse is blown your fuel pump doesn't pump either...i'm having this problem right now that my ecu fuse keep on blowing out on me...pissing the **** outta me...can't find the shorts....
Re: where is the fuel pump fuse????????? (AsiAnVenOm)
so far no diagram i have found is specific enough to say where the fuse actually is... the ecu fuse is fine as well as all others... i really think its just the fuel pump fuse, and i know there is one. i just dont know where to look for it. its not in the engine bay nor is it withmost of the others, or so it seems???!?!?!?
-Bryan-
-Bryan-
m.glisson003
10-31-2011 05:53 PM
