H22 in eg...so what axles? Help
that's right, I'm dropping an H22 in my eg and was curious on what axles I need to use with the new motor? I've heard so many different things from, keep the stock ones, get custom, use a 90-93 integra axle w/ accord intermediate shaft...AAAA so give me some feedback. thanks
Re: H22 in eg...so what axles? Help (H22EK)
So the axels and shaft have to be welded together? Can somebody give him a list of everything he needs and reasonable prices for them so he does not get ripped off. Lets help this guy out so he can actually have a phat hatch.
I've seen hasport motor mount kits, but aren't they like 600$ and I also heard you can by custom axels from them?
Re: H22 in eg...so what axles? Help (poison)
just to let you know, when i used this same setup, the axles were 1/4 inch shorter (on the end that goes into the tranny) and the axle would never "lock" into place. i tried 4 (yes) 4 different axles, and combos, none worked for me. finally had a set od DSS stage 2 made up with NO problems. Frank at DSS even knew about the short axle problem i had been having, fixed me right up. HTH
BTW: fixing me up still cost me $550 shipped. 1 year later and no problems.
DSS
DSS
Re: H22 in eg...so what axles? Help (cccya)
I would, personally recommend DSS axles for that reason, and that I have them as well and zero problems at all.
