ecu question
Old Feb 26, 2003 | 08:07 PM
Sohc Driver's Avatar
Default ecu question
Hi everyone, I just got my swap done...i have a 2001 b18b inside my 2000 honda civic EX...i could not use the b18b ecu because of the immobilizer...but i will try to get that problem fixed...temporarily..i am using the d16y8 ecu aka sohcvtec ecu...Is this ok?? right now i have a CEL but i was told by the shop that it was because i had no vtec hooked up....and should be ok to drive on temporarily? opinions please?
Khoi
Old Feb 26, 2003 | 08:15 PM
Jago's Avatar
Default Re: ecu question (Sohc Driver)
It should be ok just go easy on the gas pedal.
Post some Pics.
Old Feb 27, 2003 | 12:07 AM
Default Re: ecu question (Jago)
pics will be up in a week or so..of the swap..etc..thanks..any other opinions?
Khoi
Old Feb 27, 2003 | 04:23 AM
eg6ajk's Avatar
yes you'll be fine just don't go all crazy. in the top end it will tend to run little lean but otherwise its fine 80% of the time to use it.
invest in harness converter and OBDI ECU. less hasles and more potential
Old Feb 27, 2003 | 08:35 AM
Default Re: ecu question (eg6ajk)
thanks...i will only be running on it for a week at most.....
Khoi
MattNYC
Feb 1, 2010 09:09 AM
gook
Jun 27, 2006 05:27 PM
JokerTypeR
Apr 1, 2006 02:50 PM
Sohc Driver
Feb 27, 2003 08:36 AM
slo95cx
Feb 19, 2003 06:56 PM
