Del Sol VTEC a/c bracket...
do any of you guys have one that you're willing to sell, or know of a good place to buy one from?
i'm gonna give Manchester Honda a call tomarrow and see if they carry it. if they don't... i'll probably just have to bite the bullet and get one from my friendly local Honda dealer.
Re: Del Sol VTEC a/c bracket... (Blazin Si)
Good luck finding one...I had to spend $300 Canadian on 3 mount brackets...at least they are nice and black and glossy.
Re: Del Sol VTEC a/c bracket... (DevinW)
i have a del sol a/c bracket just make me an offer and its yours
i live in NY
pm me or email me
vtec69@techemail.com
i live in NY
pm me or email me
Re: Del Sol VTEC a/c bracket... (igotsol!)
ok, im using my stock 92 a/c compressor on my 99 gsr motor. You can use the stock gsr a/c mount to mount the civic compressor to, but you have to rig up the third bolt, and all its on by is three bolts, and i broke 1 bolt.
if you use the del sol bracket, it will bolt to the b seriers gsr motor, and the civic compressor wil bolt to that perfectly. and its done right. then you just have to go get the right belt. (not civic belt, and not gsr belt, its in the middle of the 2)
just curious, what are you going to use it for?
the engine came with the B18C a/c compressor already on it, but it doesn't look like it's going to work. i'd like to do it right, so that's why i'm looking for the Del Sol bracket.
vtec69: i'll be emailing you here shortly.
will the stock gsr a/c compressor work w/ the civic a/c condensor?? meaning is it possible to use the gsr compressor on a civic that already had a/c from the factory w/ out replacing or buying any parts???
Re: Del Sol VTEC a/c bracket... (Hybrid95CivicEX)
No, because the charge lines are different. I've tried about everything and it come down to needing the Del Sol VTEC bracket and your stock compressor if you want to keep the A/C. I yanked mine out when I did my swap a few years back and have been to lazy to put it back in.
mymomsdrunk
09-21-2008 05:52 PM
hotimportcrx
10-23-2005 03:37 PM
