b16 code 7??? how to fix
Old Mar 3, 2003 | 01:00 PM
type Gendy's Avatar
Default b16 code 7??? how to fix
I am getting the code 7 after doing my swap. Throttle position sensor? What is that? Where is it? And how can i check to see if it works?? If i can figure out which one it is, maybe it isnt wired up, or wired incorrectly...
Old Mar 3, 2003 | 01:11 PM
poison's Avatar
Default Re: b16 code 7??? how to fix (sick hatchem)
The TPS is located on the back of the throttle body. Verify it's plugged in and working properly.
Old Mar 3, 2003 | 04:21 PM
PhatOptimo's Avatar
I have the tuning instructions if you need them. 1st check the sensor like poison said.
Old Mar 3, 2003 | 04:23 PM
VTECVillain's Avatar
Default Re: b16 code 7??? how to fix (Phat_Optimo)
Yeah check to make sure it's hooked up, then from there you can trouble shoot for the correct voltage and all that. They can be fine tuned like the timing at your dsitributor with a twist so if it's working correctly, that would be your next thing to do.
Old Mar 7, 2003 | 08:26 AM
type Gendy's Avatar
Default Re: b16 code 7??? how to fix (VTECVillain)
There are two sensors on the back of the TB?? I think i know which one it is....facing the engine bay, its the plug on the left right? HOw can i fine tune it? or should i just swap my d16a6 sensor on there and try that? Or would i get the same code seeing that sensor isn't "tuned" either....
Old Mar 7, 2003 | 10:12 AM
PhatOptimo's Avatar
THE TPS is on the backside of the TB. Close to the firewall. The tps plug has 3 wires going to it. Check out this thread.
https://honda-tech.com/zerothread?id=433427
[Modified by Phat_Optimo, 1:14 PM 3/7/2003]
bam_89
Dec 10, 2009 09:44 PM
green 3gg
Sep 16, 2008 05:12 AM
integra95gsr
Jun 22, 2006 09:36 PM
Flyingchopstick
Jul 14, 2005 11:24 AM
