B20 crank pulley issue in CRX with HCP mounts
My car has been making a grinding noise when I am in hard right turns and I have not been able to figure out the problem, and it became worse when I lowered the car. Well, tonight when I was messing with my timing belt, I found my problem. The outer edge of the middle section on the crank pulley is hitting my tie rod (I believe that is what its called) and slowly grinding it away. So how can I fix this...cheaply? I believe that the 90 ls pulleys are about 3/4 inch smaller in diameter (https://honda-tech.com/zerothread?id=240208) so would that be my solution? Are there other pulleys that would work too? Here are some pics...
Re: B20 crank pulley issue in CRX with HCP mounts (Jeff C)
The CRV pulley is bigger than other B pulleys, which is why people use them with the JRSC's to get a little more boost out of it. If you aren't running A/C or PS which I doubt you are, you could use the JDM CTR pulley which is only a one belt pulley. You could also have your stock one grinded down to copy the CTR pulley design as well. The use of a LS/GSR/Si pulley might give you the added clearance you need though, so really the only way to know is to try.
Re: B20 crank pulley issue in CRX with HCP mounts (VTECVillain)
i am having the same F*&#ing problem...... The crank pulley rubs my radius rod like crazy and i cant even drive my car... I am ordering the CTR pulley though... here is a pic to show u mine....
There are a couple of huge threads about that little ctr pulley. However, there are differing opinions. Some people say just to have the oem one shaved down. Outkast, who are you ordering it from...R and D? Also, how much. Looks like it will need to balanced before installation though.
i am buying mine hopfully from http://www.jdmspecperf.com
The honda ctr pulley comes 100% balanced if i am correct
I believe that the 90 ls pulleys are about 3/4 inch smaller in diameter so would that be my solution? Are there other pulleys that would work too?
Re: B20 crank pulley issue in CRX with HCP mounts (Charlie Moua)
Is this only an issue with CRXs?
yeah i wanna know too....what about the 88-91 civic hb
EDIT: FYI...
JDM Spec Performance has them for $115+shipping. (1/2 way down the pg)
R and D Motorsports has them for $105+shipping. P/N 13811-PCT-000 (1/2 way down the pg)
[Modified by Jeff C, 1:22 PM 3/4/2003]
Just ordered mine from JDM Spec for $100 shipped. Should have it by Friday. R and D does not carry them any more.
Re: B20 crank pulley issue in CRX with HCP mounts (Outkast)
I would have thought that it is an issue with all 4g Civics and 2g crx's, but I have not heard about it before.
EDIT: FYI...
EDIT: FYI...
Re: B20 crank pulley issue in CRX with HCP mounts (sparkz)
im running a b20 crank pulley and have no problems with anyhting rubbing, although i am using hasport mounts.
Re: B20 crank pulley issue in CRX with HCP mounts (owen_the_soyboy)
I believe the CTR N1 crank pulley requires balancing....
FYI, all US EF's are the same, meaning the chassis is the same for the CRX and 88-91 Civics when putting in a B-series motor and with engine bay clearances.
Guest
Posts: n/a
Re: B20 crank pulley issue in CRX with HCP mounts (Newman)
we are using the hasport mounts with a b20vtec and havnet had any prolbme w/the radius rods and crank pully. we had to use 2 washers under each bolt on teh motor mounts to move the engine down slightly b/c it was hittin the hood slightly.
UPDATE!
Well I got the pulley on friday just like the guy said. It was $100 shipped. It weighs considerably less, about 1/3 the b20 pulley weight. It tooks me 7 trys to get the correct belt. The one I ended up with was a 29.5" belt and it had to be PDQ'd cause Advance did not stock that size. The car runs like a scolded (sp) dog now, and I can probably manage to get into the 9's too. Comparison pix below...
I have the HASport mountkit, I am able to use the crv crank pulley and it doesnt rub. The problem I do have, is my stupid engine rubs on my stupid hood.
I guess there are advantages and disadvantages for both kits.
New User
Re: B20 crank pulley issue in CRX with HCP mounts (irev210)
Re: B20 crank pulley issue in CRX with HCP mounts (usdmRob)
Good looking pics of the CTR pully. I have been running one for about a year now. There are very nice pieces. Nothing beats OEM. Heres mine.
Re: B20 crank pulley issue in CRX with HCP mounts (smokey2.0)
did you find out if it's balanced?
I cant see why Honda would not balance them from the factory.
I did spin it around my finger and it seemed fine.
