Finally: The h22 is dropped in the Teg
Took some time and effort, but here's the pics of my friends amazing gsr, w/ an h22a, itr seats, and Zeal b-6 Functions.
[Modified by integranator, 12:38 AM 3/6/2003]
[Modified by integranator, 1:01 AM 3/6/2003]
Re: Finally: The h22 is dropped in the Teg (Kris)
Looks very sweeet, I was thinking about doing that swap, how hard was it, and how much different is that swap from a civic swap??
Re: Finally: The h22 is dropped in the Teg (96b18c1vic(T))
haven't gotten the car running yet. i am waiting on my dss axles. my swap consists of hcp motor mounts and itr aem intake. the swap was cake. i spent alot of time working on the shifter and linkage trying to optimize the fitting. i'll keep you all updated. thanks kenlude97 and prospeed for your help.
[Modified by intedgra, 7:18 AM 3/6/2003]
[Modified by intedgra, 7:19 AM 3/6/2003]
Re: Finally: The h22 is dropped in the Teg (Kp_VtekNiks)
nice job, dang for a minute i thought the top radiator hose was connected to ur intake.
Re: Finally: The h22 is dropped in the Teg (Ehron)
intedgra No problem! let me/us know as soon as you get her running!! The h22 hatch is running great now. We car currenty installin NX N20!! Got rid of the Fart cannon!
Ps. what HCP kit did you get? Did you get the front mount bar?
That is the ABS that you are looking at.
[Modified by KENLUDE97, 7:27 AM 3/6/2003]
Re: Finally: The h22 is dropped in the Teg (nsxmatt)
I thought the same thing from the first pic
[Modified by 4th gen accord, 7:28 AM 3/6/2003]
Re: Finally: The h22 is dropped in the Teg (DevinW)
Ok, to clear up the confusion--- The radiator hose, was merely sitting on the intake because it was too long, so we shortened it and it fits now on the block. Also, the motor only weighs i think 80more pounds then the b18c motor, but to fit the h22a in the bay, we had to remove ac&ps which makes it about even. We haven't started the car yet, should be done soon. This car is "intedgra"s on the site.
Re: Finally: The h22 is dropped in the Teg (poison)
That's real cool...I think that is only the 2nd Teg I have seen with an H22 swap. The other one I saw was over a year ago...Did the swap go ok, or did you run into a lot of problems? What are you impressions of the car after driving it?
Re: Finally: The h22 is dropped in the Teg (b16a ferio)
Its actually not my car, its intedgra's on the site. We haven't gotten the car started yet, but he's been working little by little everytime he gets a chance to come home from school (va-tech) So he's been doing the wiring and getting everything ready for the drop in. The drop in was relatively simple, we had to cut the tranny mount a drill a new hole, and he has to mount the shift linkage from a cable accord (i believe) inside the car. i'm sure this car will be amazingly fun to drive.!!
Re: Finally: The h22 is dropped in the Teg (integranator)
Looks good. Heh... why do a lot of people put the damn FI resistor box right there? That's the 3rd car I've seen this seek (2 EG's earlier this week) with it on the driver side shock tower FYI, it's a tight fit, but you can put it in the corner, next to the firewall of the driver's side. Clean swap
Re: Finally: The h22 is dropped in the Teg (4th gen accord)
here is the way we did it
the injector resistor box was attached to the side of the egr, but these pictures are from when we first did the swap, since then we clean'd it up. There is a factory thread that you can use to bolt the EGR up to, there is a hole in the egr backing plate, I slide the hole up, so the egr sits lower and clears the hood better. Sorry for the shitty pics, but its all i got atm
We clean'd it up since then, so its not sideways and the injector resister box is properly attached to the EGR backing plate.
CLEANEST way to do it in my own opinion
_______
took the words right out of my mouth. Other than that swwet ride and
to the swap.
_______
to the swap.
