ls vtec in a crx
Old Mar 3, 2003 | 06:50 PM
wanttorace's Avatar
Default ls vtec in a crx
how hard would it be to install into a 89 crx i would be using a b16 head with b16 tranny hasport mounts b16 ecu intake manifold and dis ls axles and shiftlinkage and help as what to do would be great thanks
Old Mar 3, 2003 | 07:03 PM
VTECVillain's Avatar
Default Re: ls vtec in a crx (jjd493925)
No harder than installing a B16, same concept
Old Mar 3, 2003 | 10:09 PM
bubbajim's Avatar
ive gotta ls/vtec in my crx, just make sure you got the right engine mount on the drivers side, and if you got a 4 into 1 header its gonna hit the cross member, if youre gonna buy the hasport stuff, make sure you get the shift linkages too from them. i raised the compression by putting in b16 pistons, which made more power. the thing is a 13 second car.
Old Mar 4, 2003 | 01:11 PM
wanttorace's Avatar
Default Re: ls vtec in a crx (bubbajim)
cant i use the ls shift linkage
Old Mar 4, 2003 | 04:56 PM
bubbajim's Avatar
i dont think so, i can tell ya that i tried the del sol dohc shift linkages, and they were way too short!, its just that the crx and the ls are built differently, and that the whole tranny and engine setups are different, meaning the engine bay is sized differently. make sure and call or email hasport, dude ive raced mustang cobras, the new ones that got 300 hp , on the highway it was neck and neck from 120km/hr to 200km/hr. youll surprise a **** load of people.
Old Mar 4, 2003 | 07:55 PM
1RMDave's Avatar
what are your mods bubbajim? we talkin high, low or mid 13's?
Old Mar 4, 2003 | 08:20 PM
bubbajim's Avatar
Default Re: ls vtec in a crx (1RMDave)
ive had the ls/vtec in my del sol and i was runnin low 14's, since ive put it in my rex, ive been running it with my zdyne, 4 into 1 headers, compression around 12:1, type r cams, type r intake manifold, spoon throttle body, and 440cc injectors. ive dynoed just under 190 at the wheels, and in a crx that weighs 2100 pounds, the fukin thing flies, ive never run it at the drag strip since ive only had it in there for 2 months, but ive blown away everything, but im gonna rebuild the block to withstand more hp cuz i want it back in the del sol, and sellin the crx before the summer. to answer your question, im guessing high 13's, maybe low 13's if i ran slicks.
djenfuego2002
24
Apr 16, 2006 09:20 PM
CRXstress
Jul 6, 2005 03:28 PM
EFin' Kyle
Sep 25, 2004 02:09 PM
czech09
Oct 16, 2003 07:31 PM
NightHawkC5
Dec 12, 2002 09:21 AM
