front mount for 91 ef with b16a??
Old Feb 28, 2003 | 03:18 PM
swaplighter's Avatar
Default front mount for 91 ef with b16a??
im in the process of swapping a b16 into my hatch...ive got the hasport mount kit. only one question...do i use the front mount? or do i have to cut spot welds and relocate??
Old Feb 28, 2003 | 05:37 PM
CRXGSR's Avatar
Default Re: front mount for 91 ef with b16a?? (swaplighter)
Just use the 3 hasport mounts, and leave the front mount off.
Old Mar 1, 2003 | 10:24 AM
4ghatch's Avatar
Default Re: front mount for 91 ef with b16a?? (CRXGSR)
are you sure thats safe? i mean in the long run? i will be doing the same swap in the same car soon just wondering.
Old Mar 1, 2003 | 11:07 AM
ScottEK's Avatar
Default Re: front mount for 91 ef with b16a?? (4ghatch)
I know HCP offers a 4 mount kit, I just bought one, check my sig.
Old Mar 1, 2003 | 01:07 PM
fastwanabe's Avatar
Default Re: front mount for 91 ef with b16a?? (beta13)
When I had my B16 I used Hasports 3 mounts and used HCP front mount, worked good except for the fact that it vibrated the **** out of car
Old Mar 1, 2003 | 02:11 PM
Default Re: front mount for 91 ef with b16a?? (fastwanabe)
it seems pretty stiff with the 3 mounts...i guess ill see how it goes.
Old Mar 1, 2003 | 02:16 PM
92b16vx's Avatar
The HAsport is a stand alone system,no need for the other mounts.
Old Mar 1, 2003 | 08:10 PM
ScottEK's Avatar
Default Re: front mount for 91 ef with b16a?? (92b16vx)
In theory, would 3 mount systems shake (vibrate the car) more than a 4 mount system?
Old Mar 1, 2003 | 08:45 PM
zlambe's Avatar
I dont know but I would like to I think that is what is making mine vibrate so bad.
Old Mar 1, 2003 | 08:59 PM
Foowee's Avatar
Default Re: front mount for 91 ef with b16a?? (zlambe)
I've been running a b16a1 ef w/hasport mounts for almost three years now. No problems with only three mounts.
Old Mar 2, 2003 | 03:21 PM
NCHATCH's Avatar
drill out the spot welds and use a hammer and a chisle dont use an air hammer it will cut right thru your front cross member like butta, take the cross member off and do it on a bench then when you are finnished weld up all the holes grind it flat and bamm you have a clean jdm look
1RMDave
Feb 27, 2004 07:01 AM
Unknown Member
May 4, 2003 01:49 PM
DJ_SaNdOz
Feb 10, 2003 09:10 AM
ATS_Antone
Oct 14, 2002 06:48 AM
91sifreak
Feb 8, 2002 08:26 AM
