who can rewire this ??
I've been reseaching my swap for about 3 years now. I got everything down to a math except a few things. I have a 95 canadain civic ex. I have a 99 jdm B18c spec-r. The ecu I have is the P30-jdm. I have a brand new 95 Del Sol vtech
OBD-I engine wire harness. My question?? It plugs right into the ecu correct? I was told that the OBD-I harness would work but it wouldn't fit the injectors,distributor and alternator? Is that all of my problems or are there other places that it would not fit. HMO told me that I should have any problems. they said that the plugs might not fit, but the swap came with a engine wire harness and that I could reuse the clips. They said to just match the wire colors for they are the same and that would end any other worries. Do I need to get new injectors,distributor, and alternator from a OBD-I B-series engine OR can I rewire everything by matching the wire colors?
Re: who can rewire this ?? (turkdog)
To say that you can 'just match colors' is not necessarily accurate. Some colors probably will match. But I cannot guarantee you that they all will. Go to the Hasport website to find out how to convert OBDII to OBDI.
92TEGsrSC
01-15-2004 07:39 AM
