96 accord h22 swap problems
listen guys... hopefully you can help me. I have a 96 accord and a 95 h22 jdm swap. I got everything in, I had busted my knock sensor and got that put in and wired up, I also have one o2 sensor run in my downpipe (my obdII car had 2 and I just ran the one). I am running a p13 ecu, which I have the skunk 2 harness adapter to run it. The car cranks and idles somewhat. It idles but like barely. I am wondering if anyone that did the swap knows which plug is the o2 sensor that the p13 is reading. I am thinking that i maybe have the wrong plug plugged to the o2 sensor. One other possibility I have considered but dont think its a probability is I dont have the exhaust connected. its all run to the cat with the flex pipe, and nothing further, could my idle be messed up because the exhaust? or do you guys think its cause the o2 sensor might not be plugged in right. I do have CEL's. Thats another question... where do I jumper my car to tell what the CEL's are. Please give me some input guys. Thanks a bunch
Re: 96 accord h22 swap problems (jaosnwallace)
jumper thing is the blue cord under your glove box
go to accord room and do a serch for cell or pulling codes
there is a pic in there
good luck
good luck
nandodeyknow
10-21-2011 10:56 PM
