B16 in 93 eg no power
ok im stumped. I can get the tps adjusted right, cause i dunno where I should measure the volatge. I have no power. Timing is perfect, its a turd. idles great revs great in neutral. Once in a gear, it has nothing. Whats going on?
Re: B16 in 93 eg no power (doublejz)
So in neutral the car revs and idles good but does it die out when you put it in gear or what? Sounds like a possible clutch engagement issue to me.
Re: B16 in 93 eg no power (VTECVillain)
in neutral it revs fine, when the car is under any stress at all, it has no power. except when i upshift it has power for like a half a second then looses the power again
Loss of power...a little different than most people's bogging problems...bogs only under load and in
denraweb
02-27-2008 10:01 PM
mr nut
10
11-05-2006 03:35 PM
