ex slave cylinder on gsr tranny?
Old 10-24-2003, 03:23 PM
CoupeSi99's Avatar
Default ex slave cylinder on gsr tranny?
99 gsr tranny..on 99 si swap...we didn't have the gsr slave cylinder so we used EX slave cylinder...and the car won't shift in all the gears...just 1st and 5th...if you down shift...it sometimes goes in the rest...but is the ex slave cylinder the problem? i bled the clutch 3 times...
also...whats the absolute correct way to bleed clutch?
Old 10-24-2003, 04:29 PM
its WANG yoO's Avatar
Default Re: ex slave cylinder on gsr tranny? (CoupeSi99)
anyone? common!
Old 10-24-2003, 04:39 PM
redcivicek's Avatar
Default Re: ex slave cylinder on gsr tranny? (inJDMtegra)
ITS NOT THE PROBLEM, BECAUSE I JUST DID A AUTO TO MANUAL CONVERSION IN MY 97 HATCH WITH A LSVTEC AND USED A 94 EX SLAVE CYLINDER. THE ARE ALL THE SAME
Old 10-24-2003, 04:56 PM
Default Re: ex slave cylinder on gsr tranny? (redcivicek)
then whats the problem?
we used JDM itr shift linkage...and stock si clutch.
Old 10-24-2003, 07:13 PM
Turbogixxer's Avatar
you sure the trans did not have that problem before you owned it? Also check to see if the shift linkage is not bent.
Old 10-25-2003, 05:42 AM
Default Re: ex slave cylinder on gsr tranny? (turbogixxer)
bought the tranny from Newman at JDMshit.com...said it was a 99 with 9k miles.
shift linkage was from -b18c_powered_si--Brian Wong and seems to be straight.
Old 10-25-2003, 08:44 AM
Echo7847's Avatar
The slave cylinders are a little different, but replacements for both share the same part #. It should be working.
Did you make sure the pushrod was seated in the release fork pocket before you tightened the slave up on the tranny?
Old 10-25-2003, 10:51 AM
Default Re: ex slave cylinder on gsr tranny? (Echo7847)
yup...it was in there...slave cylinder is workin perfect when pushing the clutch...what i don't get is that the car downshifts fine..and when your sitting still its perfect also.
Old 10-26-2003, 11:40 AM
incognitoracerr's Avatar
could be the pressure plate giving you are hard time...a friend of mine has the gsr tranny on a si and he got the wrong pressure plate and he could go into gears sometimes and only in some gears not all...sometimes it would engage fine or he would have to force it...we checked the pressure plate...replaced it and all was ok...
Old 10-26-2003, 03:28 PM
Gsr_Hybrid_theory's Avatar
did u happen to check ur synchos in ur tranny? granted its got 9k on the trans... could be mangled to hell n back... my gsr trans doesnt want to downshift to 2rd and grinds goin into 2nd above 4g's
Old 10-27-2003, 04:34 AM
VTECVillain's Avatar
The B/D series slave cylinders are interchangeable so that's not your problem. If the clutch is completely bled and the pedal has a good feel, then I would say that the problem is probably in the throw-out bearing or the pressure plate.
GSRWSU
10-22-2006 11:03 AM
PearlBlueType-S
20
03-06-2006 11:10 PM
accord cd6 sir
05-25-2005 06:27 AM
mike1114
07-10-2004 06:37 PM
del_parker
09-01-2003 07:17 PM
Quick Reply: ex slave cylinder on gsr tranny?
