JDM GSR into EG problem...
the motor started up... idles good. while you gas it, it wont go anymore... seems like fuel is cutting.. will not go pass 3krpms... ???
Re: JDM GSR into EG problem... (wizzards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">you mean the codes that the ecu is giving?</TD></TR></TABLE>
Yes.
Yes.
Re: JDM GSR into EG problem... (*******)
wow, i have the same prob with the same engine, but mine will go past 3k but feels like gas is cutting out. I did a compression check and mine is low on all cylinders, maybe try that ? dunno, good luck!
pollito1320
11-26-2011 06:41 AM
baonest1
08-18-2003 11:22 AM
