92 SI HATCHBACK?GSR CLUSTER---IN A BUBBLE?!?
Re: GSR CLUSTER---IN A BUBBLE?!? (GSRHATCH187)
yeah it'll fit
all you need is Honda part # 123search123
The easy answer is that many people have gotten it in, but it isn't easy, and alot of times it isn't pretty..you also need at the least some new plugs for wiring..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRHATCH187 »</TD></TR><TR><TD CLASS="quote">will a 99 gsr cluster fit in a 92 si bubble?
if any1 knows please email bak!!</TD></TR></TABLE>
Yes you can use the 94-01 Integra cluster but it's not a direct fit and the wiring doesn't match up. You'll need the Integra harness plugs with the cluster and you'll have to rewire every wire from your 2 Civic dash plugs.
I used a 96 GSR cluster and plugs in my 92 VX about 2 years ago. To be honest it looks like *** and it takes a lot to make it look good. There is pretty much no way to make it fit perfect. You'd be much better with 92-95 Civic Si/EX or JDM SiR cluster or a big ol' Monster Tach if you just want a tach and/or higher redline.
If you decide to go through with it, I can provide you with the wiring charts to make all the changes. I would first mess around with the cluster and get it mounted the way you are satisfied with before doing any wiring.
firstgen225
02-07-2009 06:39 PM
