99 B16 into 97 Coupe - I have no B16 mounts..what do i need?
Alright guys...i read through the 6th Gen Hybrid Swap page and I'm still confused.
Here is what I've got.
Motor: 99 B16 (Civic Si)
Tranny: 99 B16 Tranny
I have all the wiring figured out, but my friend needed to keep all his B16 mounts.
So all i have is my D16 mounts...what mounts do i need to buy?
Thanks a lot and sorry I couldn't figure it out from searching.
-Paul
-Paul
Re: 99 B16 into 97 Coupe - I have no B16 mounts..what do i need? (TinyCRX)
you need b16 engine mounts
try to fit your old d-series mounts on to it before actually installing the engine..... you'll see what and why you need it.
1.) Rear transmission mount bracket - 1999-00 Civic Si - 56827-S04-N10 $28.86 Reuse the stock rubber mount.
2.) Driver's side engine mount bracket - 1999-00 Civic Si - 11910-P30-000 $40.12. Use the stock Civic 96-00 bolt studs and all other stock parts at this location.
3.) Front transmission mount bracket - 1994-01 Integra. Use the stock Civic 96-00 end rubber mount and bolt stud.
4.) A/C mount bracket - 1993-97 Del Sol. Use the stock Civic 96-00 A/C compressor.
5.) Upper transmission mount bracket - Stock Civic 1996-00.
Re: 99 B16 into 97 Coupe - I have no B16 mounts..what do i need? (VTECVillain)
THANKS SO MUCH!!!
Do i NEED the A/C mount if i'm not going to have A/C? or can i skip the mount all together?
Thanks again!
-Paul
Thanks again!
-Paul
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TinyCRX »</TD></TR><TR><TD CLASS="quote">Do i NEED the A/C mount if i'm not going to have A/C? or can i skip the mount all together?</TD></TR></TABLE>
If you don't want A/C you don't need to get the Del Sol bracket. You should get a B series A/C bracket if you don't have the one from the B16 to use as a dampening mount though.
that's what i needed to know. thanks for all your help.
-Paul
-Paul
