just completed LS swap....hittin fuel cut at 5600?
well i just finished the swap a couple days ago and finally worked up the courage to give it a run yesterday. I'm hittin the rev limiter/fuel cut at 5600rpm. heres the setup, 93 cx w/ ls motor, gs-r tranny, and a jdm cluster w/ a 7000 redline(i thought it would be perfect for my motor so i bought it....apparently not). i have a friend w/ a hatch w/ exact same setup except in a dx and another friend with an LS and they took it for a spin and said my motor is actually reving to 6800 but my tach is that far off. anyone had similar problems or any ideas at all?
Re: just completed LS swap....hittin fuel cut at 5600? (EG-UNIT)
What ECU are you using. Just because the tach says 7k doesn't mean thats where the rev limit is.
Buy or borrow a tach from someone double check the rpms or install your old cluster back in and see if it matches the revs on your JDM cluster.
Trojan Man
02-15-2010 10:51 PM
GPwhiteDB8
10-16-2003 06:42 PM
