civic si 99 ecu fit in a 99 civic hx?
Re: civic si 99 ecu fit in a 99 civic hx? (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">That would be interesting to find out.
-PHiZ</TD></TR></TABLE>
lol..yer on a roll d'night..
Re: civic si 99 ecu fit in a 99 civic hx? (AlienKrOZ)
are u talking will it plug in? or will it bolt in? im sure it will bolt in,i bolted in a p13 in my stock location in my 99 ex. its not straight, but its bolted in none the less...... and for 99-00, all the plugs are the same(obd2b i believe), but ya, it might be interesting to see if it helps it run any better... if it runs at all....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ »</TD></TR><TR><TD CLASS="quote">cause the ecu is smaller like the itr's</TD></TR></TABLE>
"size doesn't matter" ....lol..
It's the plugs on the ecu that matter. A 99 Si ecu will plug into your 99 HX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">But will it run?
i second this..
well?????
i second this..
well?????
Re: civic si 99 ecu fit in a 99 civic hx? (hondaZvic)
I wanted to know if it plugs in if i have confused anyone cause i know the 01 itr ecu doesnt plug in the 96 civic ex coupe but the gsr ecu plugs in the civic
awww.. look what i found next door.
https://honda-tech.com/zerothread?id=655420
...I don't know how an Si ecu will run w/an HX engine. Might work fine, might run too rich, might not run at all. If it does work, vtec won't kick on till 5500rpm....isn't that where an HX engine redlines? lol. The guy should just plug it in and see what happens.
nothing will blow up though..
AlienKrOZ
10-22-2003 08:27 PM
AlienKrOZ
16
10-22-2003 07:21 PM
