Do B16A throttle plates no open all the way?.....should i get a new pulley?
i have a B16A crx with a 1990 integra throttle cable. i took off my intake the other day and stepped on the gas all of the way. i noticed that the throttle plate only opened like 80%. is there an easy fix for this? someone told me to get a GSR throttle body. would it be sufficient to just buy a throttle pulley for a different b-series motor? if so, what motor?
thanks guys
thanks guys
Re: Do B16A throttle plates no open all the way?.....should i get a new pulley? (keebler65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 »</TD></TR><TR><TD CLASS="quote">i have a B16A crx with a 1990 integra throttle cable. i took off my intake the other day and stepped on the gas all of the way. i noticed that the throttle plate only opened like 80%. is there an easy fix for this? someone told me to get a GSR throttle body. would it be sufficient to just buy a throttle pulley for a different b-series motor? if so, what motor?
thanks guys</TD></TR></TABLE>
Sounds to me like your cable is loose.
Re: Do B16A throttle plates no open all the way?.....should i get a new pulley? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Sounds to me like your cable is loose.</TD></TR></TABLE>
no it is as tight as it will go without raising the idle. basically what i need is a larger diameter wheel so that i can open the throttle more with the same amount of cable travel.
ricertypeR
06-24-2008 08:44 PM
