RPM's not working on my tach. (92vx w/B18C5)
You guys are the experts and wiring has always own3d me. I can't figure this out. Every thing on my gauge cluster works fine except for the tach! I was thinking of wiring the tach directly to the distributor but I do not know which wire it is on the distributor. Can you guys tell me which wire it is. That would be the easiest thing. Like I mentioned earlier I am not good with wiring. I you guys have any suggestions let me know. Thank you very much for your help
Re: RPM's not working on my tach. (TODAeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 »</TD></TR><TR><TD CLASS="quote">I think it's the solid royal blue wire... </TD></TR></TABLE>
And if that doesn't work, you can "hard wire" it into your tach, by running the wire directly to the negative side of the igntion coil (tach signal).
Re: RPM's not working on my tach. (Newman)
Thanks for the replies guys I will try to today. Newman or anyone else can you post and or tell me were the negative side of the ignition coil is. Thanks alot you guys are the best
Re: RPM's not working on my tach. (Nerv2g)
Ok it worked I ran a wire for the little blue wire on the drivers side to the all blue wire on the plug. Thanks alot
Modified by Nerv2g at 6:13 PM 10/19/2003
99sibluehatchwitb16
01-26-2006 09:45 PM
