has anyone bought this swap?
this swap is from HMO(hmotorsonline)i was wondering if anyone has purchased this and could they tell me alil about it. its is really obd1, i no it says it but i just want to make sure.
Item 30003
B16A 92-93 Integra (XSi) Complete Change Over
Price: $ 1799.00 Plus shipping and handling.
Availability: In stock and ready to go
- Motor
- Cable Tranny (YS1)
- ECU (PR3)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Motors average 35,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition!
Item 30003
- Motor
- ECU (PR3)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
i was wondering if someone had bought this swap and could tell me about it.like is it obd1 or what cause its advertised as obd1....but it did some search and all i could find was the the jdm integra xsi were only obd0
Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">i was wondering if someone had bought this swap and could tell me about it.like is it obd1 or what cause its advertised as obd1....but it did some search and all i could find was the the jdm integra xsi were only obd0 </TD></TR></TABLE>
The 90-91 Integra's are OBD0, the 92-93 however are OBD1 but they still use a cable tranny. That particular swap would be a direct fit and plug and play (for the most part) for only a 92-93 Integra.
If you plan to swap it into an 88-91 Civic/CRX or 90-91 Integra, then you would need and OBD1 ECU jumper harness and do some extra wiring, or convert back to OBD0 which would make buying that swap kind of pointless. If you plan to install it into a 92+ Civi then you would need the HASport EG hydro to cable conversion or ditch the cable tranny for a 94+ hydro B series one.
no....i have a ls motor and i want a b16a....since it comes out my car in Jap.also i have a auto and i want a manual and this is the engine im goin to start with so i can build a poormans type r set up....this swap accomidates me cuz of the tranny and the head.
AlexanderTheGreat
Mid-Atlantic (Sales)
22
02-04-2006 11:55 AM
