h22 hybrid fuel pump
wanted to know if i would feel any difference on the "butt dyno" if i upgraded the fuel pump in my h22 ek? if so would the the prelude pump plug into civic?
any insight is much appreciated
Re: h22 hybrid fuel pump (breakaway)
Your EK pump should do fine. However if you DO feel you have the need to upgrad then I would suggest the Walbro 190 or 255 gh pumps. Very inexpensive and work wonders..
Re: (citrusdrop)
Enough for most NA applications. But the 255 can be found for around $100 installed so it you may as well get that one. Just know that you WILL need a fuel pressure regulator to help bump down the pressure once it is installed..
Re: (Jason kiDD)
which one? i found all of these.....
http://www.aeromotiveinc.com/p...ators
compact efi?
universal bypass?
hmm... not to sure about any of them..
compact efi?
universal bypass?
Re: (hondaZvic)
A1000 Injected Bypass Regulator, P/N 13101:
For 1000 HP applications that require flexibility.
Intended for use with custom fuel rails, this true billet regulator was designed specifically for use with our A1000 Fuel Pump.
Base pressure (vacuum/boost disconnected) adjustable from 30 to 70 PSI....
That one.. And it can be found for around $125 shipped..
Re: (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">does a bigger pump affect the gas mileage much? i would think so, but would like to know from the experienced.</TD></TR></TABLE>
A higher flowing fuel pump alone won't nesscarily decrease gas mileage excessivly. At least the mine hasn't.
