what tranny do i have??.s80 3006973???
Re: what tranny do i have??.s80 3006973??? (saso)
S80 is a lot of trannys...It could be a JDM ITR like mine.
Is it LSD?
http://tech.hybridgarage.com/tech/bseries.html
Modified by MADEinJAPAN at 6:59 PM 10/27/2003
Is it LSD?
Guest
Posts: n/a
Re: what tranny do i have??.s80 3006973??? (MADEinJAPAN)
If its off the motor...look through it (where the axles go) if you can see straight threw its LSD. If you see a little bar thing in the middle you don't have LSD.
If it's in the car...go drive and find out.
how would i test the lsd??
i know my motor,,is a b18a1
and the tranny is in the car
Re: what tranny do i have??.s80 3006973??? (Wrath of VTEC)
Either do a big burnout and see if both wheels turn...or bust it around a corner...do circles in a parking lot. You should be able to tell.
Do the gears seem long or short?
my car is a 94 SI hatch
it had the b18a1,,and tranny in it when i bought it
,,could i find a vin # on it??
the car does burn out when i am turning,,
any other tips to test lsd?
thanks mike
thanks mike
No No No.... Just go do a burnout with the car stopped...If both wheels spin..you have LSD. If you are peg-leggin' it you have no LSD.
Looks like that tranny does not match the motor. Didn't all the B18a1 come with YS1's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADEinJAPAN »</TD></TR><TR><TD CLASS="quote">Didn't all the B18a1 come with YS1's?</TD></TR></TABLE>
Yes they have YS1 cable tranny's. Hopefully you have a tach so see what RMP you do in 5th cruising at 70mph. It could be either a GSR, LS or ITR tranny as they all have the S80 code, but you can tell them apart by the gearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wrath of VTEC »</TD></TR><TR><TD CLASS="quote">how would i test the lsd??
jack the front up, leave the car in gear, turn one wheel by hand. if the other wheel rotates the opposite direction it has an LSD.
