What is the code for Defective ECU?
Old Oct 16, 2003 | 01:43 PM
hyperB16Turbo's Avatar
Default What is the code for Defective ECU?
My car dies while driving. After that I have to push start it.
I checked the battery and it was fine.
Old Oct 16, 2003 | 01:58 PM
poison's Avatar
Default Re: What is the code for Defective ECU? (HyperH22)
There is no "particular" code for a bad ECU. Normally if the CEL comes on with the key in the on position and STAYS on, it could be a blown fuse, bad main relay or bad ECU (when normally it's a blown fuse or bad ECU).
Please exlain more, how long does it take before it dies? Sitting at idle? Does it start again afterwords?
Old Oct 16, 2003 | 08:18 PM
PHiZ's Avatar
Default Re: What is the code for Defective ECU? (poison)
CEl stays on.. you mean when service connector is jumpered, correct?
-PHiZ
Old Oct 17, 2003 | 06:50 AM
Default Re: What is the code for Defective ECU? (PHiZ)
Yes when diagnostic is jumpered. the ecu stays on, it does blink for me to check any codes. Any ideas?
Thanks,
Zy
Old Oct 17, 2003 | 06:55 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">CEl stays on.. you mean when service connector is jumpered, correct?
-PHiZ</TD></TR></TABLE>
Yep, correct. My apologizies for not clarifying that.
Old Oct 17, 2003 | 06:57 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperH22 &raquo;</TD></TR><TR><TD CLASS="quote">Yes when diagnostic is jumpered. the ecu stays on, it does blink for me to check any codes. Any ideas?
Thanks,
Zy</TD></TR></TABLE>
Ok, so it CEL does blink correct?
Now check for the codes.
One long blink = 10
One short blink = 1
Example: two long and one short = 21
SolScifen
May 19, 2013 11:35 AM
HondaCRXsi1991
May 15, 2007 09:13 AM
civicracer94
Dec 8, 2006 06:22 PM
THEUSED
Apr 16, 2006 10:18 AM
