How long does your exedy Clutch last?
I m runing a Exedy organic for about 3k now and I feel it slipping already. I use it mostly on daily driving and ,once in awhile, to race a few ricer. I have and Ls motor w/ b16 tranny. Probubly only about 125 whp. And it not like i don't know how to drive stick so....
Just wondering, how long does yours last? 3k is kinda fast imo. What have you guys experienced?
Re: How long does your exedy Clutch last? (ZigenGSR)
i have had mine for 6k and the one before for 15k, and go to the track alot, and it is still fine, I launch at like 8500 or so, and haven't had a issue.
Re: How long does your exedy Clutch last? (99Civb20)
I've had mine for well over 6k miles, and at least 2k turbo miles making over 250HP, it chirps third and loves it. I think it's all in installation,
Clean flywheel and pressure plate with flammable brake cleaner and don't touch it again, never touch the clutch disc pad area, always get flywheel resurfaced, break in slow for over 500 miles.
Re: How long does your exedy Clutch last? (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 »</TD></TR><TR><TD CLASS="quote">I've had mine for well over 6k miles, and at least 2k turbo miles making over 250HP, it chirps third and loves it. I think it's all in installation,
Clean flywheel and pressure plate with flammable brake cleaner and don't touch it again, never touch the clutch disc pad area, always get flywheel resurfaced, break in slow for over 500 miles.</TD></TR></TABLE>
that what i did but i use paint reducer to wipe off the pp and flywheel rather that brake cleaner. It works too. get rid of oil great. So my conclusion is that exedy , unless somone say otherwise.
Re: How long does your exedy Clutch last? (ProJectCvic)
I'd bet when you take your trans off there is a bad seal, I can't see an exedy failing that soon, I know many Honda and Subaru owners putting out double what your are just on the organic disc and have no problems at all.
My Exedy Organic lasted 19k. It was clamping good until it cracked in four places. It did not like the little drag racing that I did...link.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 »</TD></TR><TR><TD CLASS="quote">I'd bet when you take your trans off there is a bad seal, I can't see an exedy failing that soon, I know many Honda and Subaru owners putting out double what your are just on the organic disc and have no problems at all.</TD></TR></TABLE>
which seal are you taking about. the ones on the axle or the one to open up the tranny.
have one in my gsr with 12k no problems
have one in my b18b racecar 1k of all hard autocross racing, no problems
key is seasoning them and installing them properly
i idunno what exact model of exedy clutch youo guys have ut i ahve seen people buy the oem replacement from exedy thinking it is a performanceclutch before and then had problems with it since it was not performing as well as expected.
Jabinya
03-31-2008 08:05 AM
