passenger side mount Auto-Manual swap
I want to do an auto to manual swap along with my H22 swap in my eg. Would I have to remove the passenger side bracket and relocate it forward a little? I have heard that you have to do it with auto to manual swap. Just want to make sure.
Re: passenger side mount Auto-Manual swap (SAVIOVEGA)
It would depend on the mount kit that you use. If you use HASport mounts, you need to remove the entire mount bracket from the frame rail so whether it's an auto or manual wouldn't be an issue. If you use HCP mounts, they utilize the frame bracket and all you do is trim it a little and redrill the bolt hole. This might be an issue, but I'm not sure if you would need to weld in a manual bracket then modify it or just modify the one in your car.
Re: (tanomack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tanomack »</TD></TR><TR><TD CLASS="quote">I think Place Racing is the only company I know of that make that mount</TD></TR></TABLE>
If you are referring to an auto to manual EG swap using a B series, yes Place Racing makes a mount for that.
getnasty
11-17-2005 12:56 PM
SprayinCX
10
06-10-2004 11:33 PM
