how much power and numbers?
Ok...here is my setup
B16a1 Sir2
Wiseco Pistons 9.0 comp.
H-Beam eagle rods
stock sleeves
LS tranny
stage 2 clutchnet
Eibach Dual Racing springs from Crower
Crower Titanium Racing Springs
Full out port/polish
Manley oversized valves
Milled head
Going to add Crower stage 3 cams and spoon chip p28 ecu this week...
Will all that in mind...when i take it to the dyno what power should I expect and when I take it to the track what should i expect...stock wheels and this is on a 94 civic coupe ex
B16a1 Sir2
H-Beam eagle rods
stock sleeves
LS tranny
stage 2 clutchnet
Milled head
Re: how much power and numbers? (incognitoracerr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incognitoracerr »</TD></TR><TR><TD CLASS="quote">Ok...here is my setup
B16a1 Sir2
H-Beam eagle rods
stock sleeves
LS tranny
stage 2 clutchnet
Milled head
Will all that in mind...when i take it to the dyno what power should I expect and when I take it to the track what should i expect...stock wheels and this is on a 94 civic coupe ex</TD></TR></TABLE>
On that setup I wouldn't look for more then maybe 145 to the front wheels. Your compression is rediculously low for stage 3 cams. I take it you plan to eventually boost this engine?
B16a1 Sir2
H-Beam eagle rods
stock sleeves
LS tranny
stage 2 clutchnet
Milled head
