Piston Slap on Built Motors???
Old 10-21-2003, 10:51 PM
turtle-eg's Avatar
Default Piston Slap on Built Motors???
I have a '95 Ls block bored .20 over to fit SRP pistons and AEM rods. My setup is LS/VTEC with a b16 gen 1 head (stock). I know the head is fine because I had it on a stock ls bottom with no problems. Now my problem is with this new block is that I get so knocking noises. My friend said it's most likely piston slap which is normal(???) on built motors, because his built motor(GE sleeved 2.0, Arias pistons, crower rods,etc...) sounds like a diesel when cold. My knocking sound gets softer when the engine warms up but it's still there. It definitly doesn't sound like a rod knock, and I reuse the rod bearings from the old rods which were for sure not knocking.
Is this really piston slap?? And is it normal for built motors??? I'm running 10w-30 oil, thinking about whiching to 20-50 to see if it sounds better.
I have been driving around like this with no problems, even 55shot NOS'ed it.
Old 10-21-2003, 11:18 PM
Combustion Contraption's Avatar
i dont know if its piston slap but i know piston slap is not "normal" on built motors. no problem should be "normal" .
Old 10-22-2003, 01:30 PM
Footwork's Avatar
Default Re: Piston Slap on Built Motors??? (turtle-eg)
It's normal for the most part.
Forged pistons are more dense, and thus take longer to expand.
My JUN/Cosworth slugs are the same way in the morning.
The pistons are smaller than the cylinder when cold.
The sound is gone when the engine is at operating temp because the slugs have expanded to the size of the cylinder.
HTH.
Old 10-22-2003, 03:20 PM
poison's Avatar
Yes, that is normal when the engine is warming up. It is also known as the "forged piston purr".
The reason it makes a slapping noise when warming up is due to the piston being a little smaller when the metal is cold, and when it is warmed up fully the metal expands and seals with the cylinder wall properly after warming up to normal operating conditions.
Old 10-22-2003, 06:38 PM
well i guess you learn somethin new every day. i never thought that would be considered normal. So, does this cause premature wear out on the sides of your cylinder walls or what?
Old 10-22-2003, 09:59 PM
turtle-eg's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">well i guess you learn somethin new every day. i never thought that would be considered normal. So, does this cause premature wear out on the sides of your cylinder walls or what?</TD></TR></TABLE>
From what I heard/saw , it doesn't cause any damage. My friend's car ran this way for a year and when he changed the head the walls were nice and clean.
Old 10-29-2003, 01:51 PM
Dyno Queen's Avatar
Default Re: (turtle-eg)
FLOATING WRISTPINS!!!!!!!!
Old 10-30-2003, 06:01 AM
go2slo96's Avatar
Location: im rubberband man, hondred grand in my hand man
why would you reuse rod bearings??? just buy new ones you are only asking for more problems down the road.
Old 10-30-2003, 07:56 PM
civicsitek GanGsTa's Avatar
Default Re: (turbo gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo gsr &raquo;</TD></TR><TR><TD CLASS="quote"> FLOATING WRISTPINS!!!!!!!! </TD></TR></TABLE>
Yup
TheHolidayCrew
12-13-2011 05:07 AM
Jeanious
08-06-2007 07:43 PM
tgreaves
07-26-2004 12:17 PM
MaxBoost
20
07-07-2003 11:50 PM
Quick Reply: Piston Slap on Built Motors???
