h22a4 into 93 accord
I just purchased a h22a4 and I want to put it in my 93 accord ex. I have read that I need an obd1 distributor and a p13 ecu and I read I will need 92-96 prelude injectors. Im not sure if all this info is correct. Some of my questions are will my accord harness work? I know I need to run vtec and knock sensor wires, what about the iab's? The coil pickups on the h22a4 are on the crank, does this pose a problem. I have a bunch of questions, but anything info you have on this swap would help. Thanks
Re: h22a4 into 93 accord (csan)
from what u sed, this is what i can answer:
ya u need. or recommended
-p13
-0bd1 dizzy, however u can wire the obd2 dizzy to work with the p13, ( i currently have this done)
-ur injectors are fine i believe. i have a 2000 h22a4 and im using my stock injectors. what year is ur motor? iknow if its 2000 and up they are high impedence(correct me if im wrong), so no need for different inj's or resistor pack.
as for the other stuff.. u might be able to find it here
https://honda-tech.com/zerothread?id=650329
-p13
you can use obd1 injectors, but you dont have too, if you used injectors out of a 4th gen im pretty sure you dont need to change the resistor pack and they are also bigger i think its like 240cc vs 320cc.
