OBD 0 PW0/PR3 oxygen sensors connections SOLVED.
For the longest time I was wrong about which plugs you connect the o2 sensors to.
So, Now I'm 100% sure that the already existing oxygen engine wire harness plug is connected to the (standing in front of the engine, facing the windshield) O2 port on the left and the one you have to add for the 1G B16 ECU to the oxgen sensor on the right.
How do I know it you ask? Well, if you drive for about 10 min on the highway at about 60MPH and all of a sudden you seem to be running lean and you have to touch the gas pedal slightly in order for you not to start to slow down, you know that the O2 sensors are reversed...
aaronhume
08-10-2006 08:54 AM
