93 dx civic b16a2 swap a/c lines?
My friend is planning on putting in his b16a2 engine in his 93 dx coupe next week. He wants to put the a/c in his car. He is not sure how to run the a/c lines. Can he use his stock D-series lines or does he need different a/c lines. If he needs different ones, which car does he get them from.
I have searched this topic already and I could't find anything....
Re: 93 dx civic b16a2 swap a/c lines? (b16v)
Reuse the same lines and compressor (don't disconnect the lines) and just unbolt it from the AC bracket. Go to the dealership and buy a P54 AC bracket and bolt that onto the B16A and your Civic compressor will bolt right up to that.
Re: 93 dx civic b16a2 swap a/c lines? (Newman)
He does not have the factory a/c anymore as he sold it along with the engine. So he will be using the a/c from the b16a.
you will need a complete us sohc civic 92-95 a/c changeover, and you will need to use a 94-95 usdm "p54" del sol dohc vtec a/c bracket and belt. done. end of story. jdm **** wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16v »</TD></TR><TR><TD CLASS="quote">He does not have the factory a/c anymore as he sold it along with the engine. So he will be using the a/c from the b16a.</TD></TR></TABLE>
your friends an idiot then
He could get the lines custom attached, but will prolly leak
buy new stock stuff
buy new stock stuff
