I have a question about some parts I traded. Give this a look. :)
I bought a 1st gen b16a motor. I traded the S1 tranny for a hydro tranny, I also traded the dist., and intake manifold. THe thing I was wondering about was the ecu. He gave me a ecu that looks small. THe number is :
37820-P2T-A11
Is this the right ECU to run my motor?
Now, waht else do I need to put this motor into my 92 civic? Can i use my stock motor mount? And will the wiring be hard? Or should I get a wire harness? Where can I get one? I have 92 integra axles, will they work? Or how about the jdm axes that came with the swap to begin with. (on the S1 cable tranny)
Oh yeah, I also need a clutch for this, so if anyone can give me a halla
37820-P2T-A11
Re: I have a question about some parts I traded. Give this a look. :) (MHhonda92)
You can keep the top tranny mount from your civic, you will need a rear bracket, front left mount and drivers side mounts from an integra gsr. Not sure about the ecu, but it sounds like they may have given you one from the newer civic si. If it is..then you can't use that because it's an obd2 ecu. You can use the stock harness from your civic but on the first gen b16s the fan switch plug is on the back of the block and will not work with the plug on your civic harness and you will have to add the vtec solenoid and oil pressure wires. Also, the distributor you traded for may or may not work with your civic harness, it depends what year distributor it is.
By the way, you spelled "holler" wrong in your post..it's ok though, probably a typo.
Re: I have a question about some parts I traded. Give this a look. :) (Willis)
That ecu is for a 99+ Si based on this info from Locash:
[ecu legend]
PG7 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR3 : 89-91 JDM B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-00 OBD-1 DelSol DOHC Vtec Si/EG SiR
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75 : 92-95 OBD-1 Integra LS/GS
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2T : 99+ OBD-2 Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
HTH,
[ecu legend]
PM8 : 88-91 CRX HF
HTH,
Re: I have a question about some parts I traded. Give this a look. :) (Trey)
OK. so what ecu should I use??? I could probably chip a p28, right? SO, does anyone want to trade my p2t uce for a chipped p28??? Let me know.
do you know where I can get the other mounts I need??? ANd what year gsr do I need to get the mounts off of???
u seriously need to do some more of your own research... I'm not trying to be mean but there are hundreds of websites that have every question you could probably come up with.. answered... http://www.hasport.com
has a listing of all things you'll need.. do some searches because I'm sure that people have even already asked these same questions on this board....
-x-
-x-
Re: I have a question about some parts I traded. Give this a look. :) (Xav H22EG8)
Yeah, I have been to hasport many times, they don't help me worth ****. ALl I was wanting to know is what year motor mounts from the gsr to fit my motor into my 92 civic. I need this info so I can tell the salvage yards what year integra I need all the mounts from. Casue you know the people at salvage yards won't help you worth a ****.
1994-2001 acura integra gsr or type r mounts are what you need.
[Modified by Willis, 10:00 PM 1/7/2002]
