integra parts in a eg hatch?
well this just hapened to my teg
https://honda-tech.com/zerothread?id=106476
so now i am thinking of buying a eg hatch and moving whatever is good from the teg to the hatch
from what i have read both the 3rd get teg and 5gen civic share the same chassie, so all of my suspension, swaybars, brakes should fit, correct?
the engine is still go in the teg and i just had it rebuilt, (only has 800 miles on it since the rebuild) so it will also go into the hatch, and i believe that the b18b motor mounts can be bolted right in, correct?
now, if i put the engine in, along with the ecu, can i also put in the ac, power steering, gauge cluster, i may even swap over the whole wire harness if needed, will this work, or am i just dreaming, thanks
_______
burnoutboy
06-21-2014 01:19 PM
