-3an too small for VTEC feed?
Old Dec 24, 2001 | 06:58 PM
HX_Guy's Avatar
Default -3an too small for VTEC feed?
Im currently running a BSPT fitting off the rear of the block to a -3an line, then to a T fitting which goes to my oil pressure gauge and to my stock sensor.
Can I also use -3an line for the VTEC feed? Or is it too small? Should I run -4an off the block and to the head?
The thing is, the 1/8" BSPT off the block is TINY! I mean the hole in the fitting is like a -2an. I get 80+ PSI above 4000 RPMs which is more then enough to activate VTEC.
Old Dec 24, 2001 | 07:38 PM
KawiGreenVTEC's Avatar
Default Re: -3an too small for VTEC feed? (HX_Guy)
Use the 4an
Old Dec 24, 2001 | 07:42 PM
HX_Guy's Avatar
Default Re: -3an too small for VTEC feed? (KawiGreenVTEC)
Reason?
Old Dec 24, 2001 | 08:14 PM
In my experiences the 3an can be restrictive in oil flow.
Old Dec 24, 2001 | 09:25 PM
rainforest's Avatar
everyone i know uses 3an either works so dont worry to much.
Old Dec 24, 2001 | 11:03 PM
Default Re: -3an too small for VTEC feed? (rainforest)
Cool I will note that for future reference, everyone I know uses the 4an and has had problems with it, but maybe that was a personal thing for them
ezark
Jun 24, 2002 07:41 PM
b20b
Feb 22, 2002 03:45 AM
HX_Guy
Dec 26, 2001 12:50 PM
HX_Guy
Dec 26, 2001 06:30 AM
HX_Guy
Dec 25, 2001 08:21 AM
