b18c1 question
Old Jan 4, 2002 | 06:47 AM
tr4il's Avatar
Default b18c1 question
if i get a b18c1 to i have to spend my extra money and go buy new spark plugs, spark plug wires, rotor, timing belt, water pump and tension pulley to make it run?
Old Jan 4, 2002 | 07:15 AM
DragII's Avatar
25 Year Member
Default Re: b18c1 question (tr4il)
no, but it's a good Idea to do the plugs, timing belt, and water pump.
Old Jan 4, 2002 | 10:53 AM
tr4il's Avatar
Default Re: b18c1 question (DragII)
so basically all i listed but te rotor?? are these things expensive?
Old Jan 4, 2002 | 06:41 PM
civic97dx's Avatar
it all dopends on how many miles are on the motor. I just finished my swap and all I did was change the oil, trans fluid, Thermostat, coolent, and plugs. But mine only has 30k on it so it dosen't really need anything. Just check everything and if it looks worn , then it sure be replaced. There is nothing worse than finishing your swap and having to take off to buy something to get it to run. Just look at everything ahead of time and plan everything.
good luck!
FlewByU352
Oct 9, 2009 04:01 AM
Ebony and Ivory
Jun 9, 2005 09:45 PM
99exd16y8
Jun 9, 2005 09:49 AM
NoNOSgsr!
Jul 15, 2002 11:46 AM
imported204
Apr 27, 2002 11:23 AM
