Clutch for B16a cable tranny?
Re: Clutch for B16a cable tranny? (Rexman)
The pressure plate will fit, the disc will not. All cable transmission except for the YS1 use a 90-91 Integra clutch disc. The cable transmissions have a smaller input shaft. If you have a YS1 transmission then you can use a 94+ B-series clutch kit. Although the throw out bearing won't fit.
You can use the complete OEM clutch kit from a 90-93 GSR. If you need the part #, check in the Sport Compact Car magazine (I believe the October issue) and the part # is listed.
Re: Clutch for B16a cable tranny? (chi1874436)
no,they only made gsr's 92 and up. and if you have a japanese b16 trans you need a 90-91 integra clutch disk, you cannot use any 92 and up integra disk though the pp will work.
[Modified by internet ay, 3:39 PM 1/1/2002]
Former Moderator
Re: Clutch for B16a cable tranny? (internet ay)
Right. 1990-1991 discs ARE different from the 1992-1993 discs. Even the Integra LS from 1991-1992 uses a different disc.
HONDA_TYPE_R
09-13-2004 08:51 AM
Cyber ITR
11-01-2003 05:41 AM
crx1856
06-05-2003 10:12 PM
