Shiftlinkage question in an EG.
Old Jan 9, 2002 | 08:21 AM
275Performance's Avatar
Default Shiftlinkage question in an EG.
Would the Del Sol Vtec shiftlinkage work in a 95 civic ex with a b20/LStranny? I know the Teg linkage works.
Old Jan 9, 2002 | 08:47 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Shiftlinkage question in an EG. (drivingchallenge)
i 'heard' that the del sol vtec linkage is longer than the other b-series excluding the si also.
Old Jan 9, 2002 | 08:53 AM
Turbo LS's Avatar
Default Re: Shiftlinkage question in an EG. (not so civic)
Actually I think it is shorter but either way it won't work....you need the Integra shift linkage or 99-00 Si linkage
Old Jan 9, 2002 | 09:12 AM
Default Re: Shiftlinkage question in an EG. (Turbo LS)
So any DOHC linkage besides the Del Sol will work then?
Old Jan 9, 2002 | 09:30 AM
DR. ON POINT's Avatar
Banned
yesany b series will work except the del sol....del sol is longer
[Modified by On Point EK, 10:31 AM 1/9/2002]
Old Jan 9, 2002 | 09:49 AM
jg's Avatar
jg
cruise the old hybrid boards. Good basic swap info. B20 mounts the same as LS. http://hybrid.honda-perf.org/index.html
there's also good stuff here that comes up if you use the search function.
Old Jan 11, 2002 | 03:15 PM
supergreenNA1's Avatar
New User
Default Re: Shiftlinkage question in an EG. (jg)
um... so is the del sol linkage shorter or longer???
we have one vote for each so far.
Old Jan 11, 2002 | 04:57 PM
91sifreak's Avatar
New User
Default Re: Shiftlinkage question in an EG. (supergreenSol)
Hey check this site, I haven't done they EG swap yet but on here it says how to do the b18c swap and I think, which I may be wrong, but they say a gsr linkage will fit perfect, the site is c-speedracing.com. Hope it helps
Old Jan 11, 2002 | 04:58 PM
Banned
its longer....Antonio tried to do it
ejv8s10
Sep 3, 2014 11:52 AM
secularhonda
12
Mar 17, 2014 11:22 PM
jdm as fk
Sep 29, 2010 08:12 AM
shanerv
Mar 28, 2005 06:31 AM
11secdx
May 15, 2003 08:42 PM
