CRVTEC ECU Question
Re: CRVTEC ECU Question (Red Civic T)
Thats what I thought. But I had heard that it wasn't going to work right with hondata. I don't see why not. In fact I just found it on Hondata's site.
[Modified by drivingchallenge, 8:41 PM 1/8/2002]
New User
Re: CRVTEC ECU Question (misledyouth)
Hmmm, can't tell you about Hondata. Right now I run the PR3 on my modded b16a with a Mugen clone program.
I heard (and therefore know nothing about) Hondata only being for OBD I cars - will have to look into this. Theoretically if you have a wide band A-F meter and VTEC fuel controller, you can do a slightly crude but effective mockup of air-fuel curves....
I can use the Pr3. But where do you find the OBD O uncut wiring harness? Wouldn't a P30 from a 95 Del Sol run the motor? The car is 95 Civic EX with crvtec running a b16a head.
[Modified by drivingchallenge, 9:44 AM 1/9/2002]
Re: CRVTEC ECU Question (drivingchallenge)
Just use the P28 and rechip it cuz it doesn't sense a knock sensor. If you want that sensor then use a 94+ GSR (P72) or a Del Sol (P30) just use whatever you want. Ur not goin to be able to use the PR3 tho cuz it is an OBD 0 ECU. Laterz
