b16a head on a gsr block?
well i need speed for my civic si but i need torque and that's something that they dont have so if i changed the block would that make a good improvement any sugestions would help. thanks
Re: b16a head on a gsr block? (Honda_HatchEG)
You will want to change out the pistons to raise up the compression first.
But once that is done, the difference between that and a b16a is night and day
Re: b16a head on a gsr block? (sgT)
You would kind of be makin a ITR motor. The only difference between an ITR head and ur B16A would be that the ITR is mildly ported and has a different valvetrain and camshafts. You would also want to change out the pistons for ITR or ur B16A's since the greater volume of the B16A head would put your C/R at about 9.8:1. Have fun!
[Modified by JDMspecEG6, 2:10 AM 12/31/2001]
Re: b16a head on a gsr block? (JDMspecEG6)
why not try some ctr cams and pistons. cheaper than a gsr block and that will bring your cr up and the cams are much better than the us spec stuff.
KnuckleZ
37
10-30-2009 08:03 AM
