code 2 or 20?
Old Dec 25, 2001 | 08:18 AM
Frosty_spl's Avatar
Default code 2 or 20?
i started using my friends non chipped pr3 and now im getting a code 2, maybe its a 20 im not sure. everything seems to be ok. the vtec doesent work like always. whats going on?
Old Dec 25, 2001 | 08:29 AM
rainforest's Avatar
Default Re: code 2 or 20? (Frosty_siR)
thats seconday o2 sensor. 20 is electronic load i think it deffinatly would be a number 2.
Old Dec 25, 2001 | 01:54 PM
Quick 200k Mile Motor's Avatar
Default Re: code 2 or 20? (rainforest)
Thats interesting.. I didnt really know for sure if the PR3 ECU had a secondary O2 ..Hell, its a OBD-0 ECU!!
What would be done to eliminate the secondary O2 wiring?
Old Dec 26, 2001 | 11:02 AM
walker111's Avatar
Default Re: code 2 or 20? (Quick 200k Mile Motor)
my car once through a code 20 which is the eld located under the engine bay fuse box. it also made my vtec not work. after lots of trouble shootin i found that it was a wire that had grounded out under my dash. if you havent fixed the problem yet hit me back and ill give you the steps to find out what the f@#$ is going on
91GS-R in Vegas
Dec 20, 2007 04:55 PM
the jdmchop
May 23, 2006 11:26 AM
JD95hatch
May 18, 2006 02:51 PM
denshu
Jan 11, 2004 07:46 AM
