Integra Type-R Block Code
Old Dec 26, 2001 | 06:08 PM
VTECVillain's Avatar
Default Integra Type-R Block Code
Does anyone know the motor block code for a JDM Integra Type-R. Is it just a B18C or a B18C-R??? I know there is a JDM GS-R motor with the block code B18C so I thought that maybe the Type-R is different.
Old Dec 26, 2001 | 06:26 PM
CRX_VTEC's Avatar
Default Re: Integra Type-R Block Code (VTECVillain)
I think it just says B18C
Old Dec 26, 2001 | 06:45 PM
Kamin's Avatar
Default Re: Integra Type-R Block Code (CRX_VTEC)
for jdm
its b18c
for usdm its b18c5.
Old Dec 26, 2001 | 07:39 PM
HX_Guy's Avatar
Default Re: Integra Type-R Block Code (KAMiN)
..and if its from Europe its B18C6
Actually I dont know if ALL Europe ITRs are B18C6...but I know some are.
Old Dec 27, 2001 | 04:24 AM
92Hatcher's Avatar
does anyone know how to tell the different years of JDM ITRs blocks apart (ie and 98 or newer vs a 97 or older)?
I thought there was a manufacture date somewhere?
Any other observable differences on a 98 or newer JDM ITR swap?
Old Dec 27, 2001 | 05:33 AM
Trey's Avatar
25 Year Member
Default Re: Integra Type-R Block Code (92Hatcher)
Well if you are worried about buying a ITR and getting a GSR, just look at the intake manifold. The GSR is upside down. ITR looks like the 99-00 Si.
Also, look at the ecu, there will be a sticker with a P73 in the middle if it's an ITR. P72 for the GSR.
Old Dec 27, 2001 | 12:17 PM
B18CXr's Avatar
hit up Jeff S. he has the key for telling the years of blocks
Old Dec 27, 2001 | 12:54 PM
wuhungsixxx's Avatar
New User
Default Re: Integra Type-R Block Code (B18CXr)
i think if u lookon the head just above the exhaust manifold it is stamped on it...there are several circles and inside them are two numerical digits with a slash between them....ie: 9/4...1994...i think its the far left circle...someone correct me if im wrong thats just what iv heard....dont know how u can tell the block tho
Old Dec 28, 2001 | 12:45 PM
Default Re: Integra Type-R Block Code (Trey)
I'm not looking to buy a Type-R all I wondered was about the block code. I have a 99 B18C1 in my VX. I know how to tell the difference between the intake manifolds and the head. Just wondered about the block code that's all. So the JDM GS-R and Type-R are both B18C? From what I've read the block is identical to the GS-R but the pistons, head and everything up top is different.
Old Dec 29, 2001 | 03:10 PM
GZR4DR's Avatar
Block is not the same. It uses a heavier crank with more counter-weights, different rods, and also has higher compression pisons. The JDM GSR and ITR both say B18C. As for telling year, if you don't have the head, i don't know.
FLATOUTRACING
Nov 12, 2007 11:42 AM
JDMlude698
Nov 26, 2004 07:11 AM
red civic standard
Dec 12, 2002 06:23 PM
slowbie-one-kanobie
Jan 21, 2002 11:41 AM
VTECVillain
Dec 26, 2001 09:15 PM
