intake problems??????
Old Jan 6, 2002 | 11:40 AM
JKim0901's Avatar
Default intake problems??????
which intake should i use with a hybrid?? i got a b18c5 in a EG and the aem pipe made for the EG dont seem to be all that big in diameter. Did anyone do a dyno run with this? would i be losing any power? or is it just nothing major that i dont have to worry about. thanks guys
Old Jan 6, 2002 | 04:16 PM
Jared's Avatar
Default Re: intake problems?????? (JDM EG CPE)
use the aem intake made for the ITR
Old Jan 6, 2002 | 06:00 PM
JKim0901's Avatar
Default Re: intake problems?????? (Jared)
dosent the type r one rub on the engine mount though?
Old Jan 7, 2002 | 05:13 AM
hybridreams's Avatar
Hey I had the same problem as you, well, sort of...
...the Skunk2 intake manifold on my B18C1 raised my throttle body to the same height as your Type R's, I was told that the DOHC VTEC Del Sol or 99-00 Civic Si AEM CAI fits best. If you have a strut bar, the Si CAI MAY rub a little, but I plan on getting the Si CAI anyways (Del Sol - 2.5'' Si - 2.75'' Type R - 3"). Wider piping. Hope this helps some.
Old Jan 7, 2002 | 09:10 PM
JKim0901's Avatar
Default Re: intake problems?????? (hybridreams)
i just picked up one thats for a civic si 92-95 and the piping is a little smaller in diameter than the tb but it fits really good on the chassis so im cool with it thanks. BTW the 99 SI one has extra holes for the sensor if you dont mind that sticking out there...
Old Jan 8, 2002 | 06:47 AM
MugenEg6's Avatar
u should use a 94 delsol vtec
EF_LSVtec
Jun 24, 2003 08:51 PM
Jet Phi
Jan 17, 2003 09:45 AM
PM-Performance
Aug 6, 2002 07:26 AM
DB8
Feb 21, 2002 05:45 PM
hybridreams
Dec 30, 2001 03:08 PM
